1030 Case-Hyd. Lift
Elliot D. Weave
05-13-1999 19:50:46
My drawbar lift will not work very well, I changed the hyd filter and it still does not work very well. Does anyone know if there is something I need to look for other than the filter?
bud
05-16-1999 06:46:04
 Re: 1030 Case-Hyd. Lift in reply to Elliot D. Weaver, 05-13-1999 19:50:46
John Ded. helped me with same problem, just clean control valve out, speedometer gearpieces broke off and got caught in the control valve( it is located under the floor panel, take seat out and you wil find it a small plate on right side has three ports under it just clean them out) if you need any help just e-mail me,\. John Ded. probly will see your pso and help also
