2470 Smokes Alot?
Ryan
10-01-2003 05:17:49
The other day while using my 2470 on the chisel plow, I noticed that it was smoking alot of pure Black smoke. It never used to do this, and it was not being pulled hard either. Could it be dirty injectors or something else? The motor is solid and only has 975 HRS. on a major overhaul, so I don't think that that is the problem.
Ryan
10-01-2003 18:52:55
 Re: 2470 Smokes Alot? in reply to Ryan, 10-01-2003 05:17:49
Found the problem. I put a bottle of fuel injector cleaner in, I used it for about 10 minutes and it now runs perfect w/ lots of power and no smoke. I knew it wasn't any filters as they were all put on new about a week ago. Thanks for the suggestions.
turbo
10-01-2003 07:21:08
Have you been operating in field with large leaves like corn? If your front grill is not sealed tight, then leaves restrict or plug you aspirator in the upper right corner and starve it for air.
Max
10-01-2003 06:31:17
Try changing the fuel filters. Those tricky Case engines do opposite of what you think they would do.
Roger
10-01-2003 06:23:16
How is the air filter ? My 1370 smoked like crazy after I got it, changed filters & exhaust cleaned right up, it didn't look like previous owners ever changed filters
