How many own a case 300 series? just cuious
Dave Wa
10-03-2003 09:36:33
Also don't hear much about them on this board I have a (311 high crop) I just bought and need to fix. Can anyone tell me how much weight the eagle hitch can lift thanks Dave
BillK
10-07-2003 18:17:02
 Re: How many own a case 300 series? just cuious in reply to Dave Wa, 10-03-2003 09:36:33
My Dad (lives in NW Iowa) bought a '57 311 in '61 and still has it. It had a 3x14 mounted plow. It has a wide front end. He put it on the baler (a 14T JD), and me in the driver seat. I was 9 years old. Dad plowed all the ground for 100 acres of corn for 3 years, then traded his 'G' JD for a 3020 and a 4 bottom plow. Then we ran both plows for several years.
He still uses it for grading the driveway. It could use a new battery and other little parts, but otherwise runs good.
Dave Wa
10-06-2003 08:11:55
Boy, more than I thought, The only reason was cause I never here much on these having trouble. I will be starting on getting mine in the shop As soon as I get room the motor is stuck But I'm sure it shouldn't be to bad. thanks for answering back Dave
Jim Yadon
10-03-2003 18:22:03
I have a 311 roundnose and just down the road from Doug in Indiana. I use mine everyday, from mowing with a finish mower and 6' tiller. Has no problems picking up my gigantic bush hog. Bounces the front a little bit if I hit a hole or two. Didn't lift real good until I put new o ring and retaining ring. To replace the old leather seal. It works great now and is real fast compared to what it use to do.
Jim
Doug in Indiana
10-03-2003 16:42:35
Hi ,, Ive got a 300 roundnose;; It's got a single front wheel. This is the only one like this that I've seen,( but I don't get out of the house much!!!) The Eagle has enough power to pick up everything that I've hooked to it. Mower , blade , graderbox, etc. Doug
george md
10-03-2003 20:55:40
 Re: Re: How many own a case 300 series? just cuio in reply to Doug in Indiana, 10-03-2003 16:42:35
I've got a 300 round grille utility with side
mount 30H mower , had it since 59 . it will lift
a 7-6 lilliston rotary mower . Son in law has 3
300's , a utility, a wide front , and a narrow
front . All gas .
george
Larry806
10-03-2003 19:13:37
Hi Doug How you been? Ever do anything with that vac you got from me I've got 2 300 round nose tractors I bought in a estate. 1 only has 590 hours & a heavy mid mount mower The other has a loader & backhoe on it
dctom
10-03-2003 16:57:10
HI I KNOW A MAN THAT HAS 5 OF THEM, USE THEM FOR CHORE TRACTORS, TRAVEL FROM FARM TO FARM FAST ANOTHER GUY HAS ONE THAT HIS GRANDPA BOUGHT NEW IN 57 STILL RUNNING GOOD DCTOM
Lincoln
10-03-2003 14:15:07
I have a 310 round nose. Don't know how much the Eagle hitch will lif, but it seems strong for such a little tractor.
Kennyp
10-03-2003 14:10:51
, Hey, I got the answer for you. I asked this spring how much lift it had and some one told me 26 inches...lots of help. I went ahead and bought the 6 foot bush hog and it yanks if of the groung like a champ. Pounds I don't know but its pretty darned good. I think the smaller tractors may have a smaller ram inside acording to the parts book. Mine is the Regular 311.
Greg
10-03-2003 20:31:25
 Re: Re: How many own a case 300 series? just cuio in reply to Kennyp, 10-03-2003 14:10:51
I have three of those 300's. One is a round nose one is a square nose diesel and a square nose gas tractor. I use them all for choring and never had a problem with lifting anything.
cb
10-03-2003 11:33:54
We used to move 2000 lb round bales with our VAC with a 3 point bale spear.
Sometimes you had to keep the front end of the tractors downhill in order to get the bale off the ground (and keep the front end of the tractor on the ground)
You learned to drive with the brakes and having the front end off the ground. Be careful you can break the front end if the bale falls off while the front end is up and she comes down really fast and hard.
I own a 300b but I need to put it back together. a 300 is just super-sized VAC.
John H-WI
10-03-2003 16:00:31
 Re: Re: How many own a case 300 series? just cuio in reply to cb, 10-03-2003 11:33:54
Hey CB, its more than a super sized VAC. We had a VAC in the past also but we pulled three 14's in the hills with our 300 plus live power. Used it on the baler pulling the wagon on the hills. Best little tractor we had around. Wiish I could find a 350 to restore.
C. Amick
10-03-2003 09:52:13
I don't know how much weight my 311 will lift, but it won't pull the front wheels off the ground.
Trevor
10-14-2003 16:17:09
 Re: Re: How many own a case 300 series? just cuio in reply to C. Amick, 10-03-2003 09:52:13
I have a set of side shields dad says is off of a 300 .They have the rollers on them. Wedont have any use fo them .Iwould like to sell or possibly trade for oliver 77,88 parts.Theyhave surface rust on them but are straight any ideas on value? Thanks.
