CASE DC
TIM B.
05-17-1999 05:48:39
Can someone tell me where I drain the transaxle fluid and add fluid on a Case DC. Is there someplace to check the level? THANKS
martin
05-17-1999 09:45:45
 Re: CASE DC in reply to TIM B., 05-17-1999 05:48:39
You drain the transaxle fluid from a big screw in plug under the belt pulley, at the bottom of the tractor. Alot will come out. You add it in a place under the seat to the right. its a screw plug. It has a square head. YOu check the level straight down from the filler hole, about halfway down. its to the right of the motor lift. When the oil starts coming out of this hole, you are full. The plug is a small square head plug.
