1030 Power Steering Pump Problems
Sam
10-16-2003 17:55:07
Early Model 1030, Hard to turn, occasionally cuts out for a sec.
Not the belt, not a lack of fluid. Has steadily got worse over the past 2 years. Since I got a second 1030 I realize this steering has never been right. So can I remove and clean, adjust. I know there is a filter in the pump, will that solve all my problems?
Any hints?
North M
10-17-2003 09:39:22
 Re: 1030 Power Steering Pump Problems in reply to Sam, 10-16-2003 17:55:07
I have about the same problem with a set of 930 ck tractors. The one that I had was always hard to steer but it worked with some resistance. I had the cylinder rebuilt, hose's are good and pump is putting out good volume. Not sure what pressure it is capable of producing. I bought another 930 here 2 years ago and it steers with one hand on the wheel. I did notice the setup with the cylinder is two different design's. I even went as far to swap the cylinders from tractor to tractor and the hard steering one is now the good one. I would think it would have to be the cylinder with yours.
JCmarleau
10-16-2003 20:20:01
if ever need used part i may help my e mail is jcmarleau@aol.com
Roger
10-16-2003 18:28:28
There is a rebuild kit from Eaton for about $ 160 that has new rollers & the ring inside that the rollers run on. Maybe they are worn enough that replacement would help. Just a thought.
