1030 hydraulics finally working...
Jens Andersen,
10-18-2003 07:25:09
I could not get my remoteoutlets to work. Replaced
the O-ring at the flange, didnīt help. Took the
pump apart seemed okay except there were a litle
slop between the gears. Put more oil in the trans-
mission up to the top mark, didnīt help. Blew air
backwards thru the suctionstrainer, and heard it
buble. Put the pump back on and now it worked, the
engine drops 100-150 rpm when it is pumping thru
the pressure relief valve, so the pump seems okay.
Have you guys ever experienced the suctionstrainer
to be plugged. Well I am draining the oil and blowing gas thru the strainer trying to clean it.
Best Wishes Jens Andersen, Denmark
Jim Handke
10-18-2003 11:34:12
 Re: 1030 hydraulics finally working... in reply to Jens Andersen, Denmark, 10-18-2003 07:25:09
We've never seen them completely plugged. When we were replacing ring gears & pinions we have seen them 1/2 to 1/3 plugged with shavings, pieces off the pinion shaft, and other stuff. I hope this isn't an indication of pending troubles with the drive train.
John Saeli
10-18-2003 16:26:37
 Re: Re: 1030 hydraulics finally working... in reply to Jim Handke, 10-18-2003 11:34:12
Hey Jim; You talk about replacing ring & pinions in 1030's in the plural like you've done it more than once. LOL, snicker, grin, ect....
