VAI
Bob
10-27-2003 20:36:45
I have a 1944 VAI and have a chance to get a 1952 VA. I need a rear wheel rim and would like to add a belt pully also the eagle hitch. Will these from the 1952 work on my 1944 VAI.
mike
10-30-2003 00:21:49
 Re: VAI in reply to Bob, 10-27-2003 20:36:45
Hi bob most va or vac had 28" wheels while the 2 vai's i had were 24" might want to check this as far as the belt pully and stuff you should be fine the 47 vai i am parting out had the gear for the belt pulley but not the shaft and pulley so it should be a bolt on good luck mike
Bob
10-30-2003 18:44:28
 Re: Re: VAI in reply to mike, 10-30-2003 00:21:49
Hi Mike,
Thanks for the information. I'll check the wheel. I don't think the 1944 vai came with a belt pully but there is a spot for it and I think it would look nice. The hitch I would like to put to use.
Thanks Bob
mike
10-30-2003 19:00:21
 Re: Re: Re: VAI in reply to Bob, 10-30-2003 18:44:28
I agree that they didnt have the belt pulley (no need on industrial tractor ) but the 43 and 47 vai both had the gear on the main shaft just pull the 4 bolt cover and see if the gear is there there a good little tractor though good luck mike
