1896 problems
Luke Stricker
10-29-2003 10:11:25
I have an 1896 that the lift cylinder is coming out the back of the center case. Has anyone heard of this problem? Any ideas on where to get used parts to fix it? Thanks Luke
darBy
10-29-2003 21:55:08
 Re: 1896 problems in reply to Luke Stricker, 10-29-2003 10:11:25
I replaced the trans/rear housing on a neighbor's 2294 because of the same problem. There is a safety relief valve that can be installed on the three point valve that would have saved the housing.
turbo
10-29-2003 11:09:57
If you are talking about the 3pt lift cylinder, yes I have seen it before. Your cancel linkage between the rockshaft and the control valve was not adjusted correctly. The valve said raise, pump was on high pressure and the housing finally gave out.
