'54 DC Are there any more options?
Glenn FitzGeral
11-18-2003 20:24:50
I have a Rock Island built gasoline engine 1954 DC Case. It has live PTO, Eagle Hitch, dual spool hydrolics, foot clutch, adjustable wide front end, foot feed throttle, and a torsion spring seat. Were there any other options available that year? Also what is the difference between a Rock Island built DC and a Racine built? Is one considered more desirable than the other?
Don L.
11-19-2003 05:36:11
 Re: '54 DC Are there any more options? in reply to Glenn FitzGerald, 11-18-2003 20:24:50
How about a factory hour meter, tools for the tool box, tire pump,20 gpm hyd pump, factory cushion for the seat,weights frt and rear on the wheels and another set for the frame, full steel was a option, idler pulley for belt work that goes on the wide frt.,resilient belt pulley, LP GAS or low cost fuel engine, spark arresting muffler,. Never heard of a Rock Island DC ! DCTOM will provide info soon.
Don L.
Don Rudolph
11-19-2003 15:40:18
 Re: Re: '54 DC Are there any more options? in reply to Don L., 11-19-2003 05:36:11
How about radiator shutters and extended rear axles? An adjustable wide front would turn it into a DC3.
Mike Schotte
11-19-2003 05:11:16
To my knowledge there were never any Rock Island built DCs... only Racine built ones.
What makes you think it's a Rock Island tractor?
-S.
Glenn FitzGerald
11-19-2003 06:01:12
 Re: Re: '54 DC Are there any more options? in reply to Mike Schotte, 11-19-2003 05:11:16
I don't have my serial number with me right now, but as I remember the first two digits are 80. Also if I remember correctly, my 'Full Steam Ahead' book states all DC's starting with serial #80 were Rock Island built. To know the exact year of production one would need the number off the engine. Well, for me that's not an option in that I bought my tractor with huge holes through the block and a connecting rod or two missing! Also, I understand foot clutch was available only in '54. However mine didn't come with foot clutch either. I added this option.
dctom
11-19-2003 06:29:38
 Re: Re: Re: '54 DC Are there any more options? in reply to Glenn FitzGerald, 11-19-2003 06:01:12
If you beleive every thing you read in full stem ahead you will be misinformed a lot there was no rock island DC's post the serial number and i will post when it was built and where,
rock island was 60 and racine was 80 in 53 and 54 tom
Tom Railsback
11-19-2003 18:09:37
 Re: Re: Re: Re: '54 DC Are there any more option in reply to dctom, 11-19-2003 06:29:38
Should we tell them all aout the "grand poopah"?
Nah, I don't think so. We know he's never wrong, don't we?
Glenn FitzGerald
11-19-2003 17:57:14
Tom, I will check on that serial number. Now that you say it, I think mine does start with an 80. My tractor is stored at my brother's house for the winter. I'm having him get the serial number for me. Thanks, Glenn F.
