18-32 CROSSMOTOR SERIAL NUMBER - WHERE IS IT ???
I NEED GLASSES
11-22-2003 21:15:38
I'm thinking there should be a brass plate on the
inside of the fender, but it appears to be gone.
Should there be a serial number stamped into the frame somewhere behind the front wheels or is it
up on the motor block somewhere? Any help would be appreciated.
Alan Parsons
11-23-2003 11:34:42
 Re: 18-32 CROSSMOTOR SERIAL NUMBER - WHERE IS IT ? in reply to I NEED GLASSES, 11-22-2003 21:15:38
I am looking at an original catalog
No. 104H Repair Parts List model "K" Tractor 18-32(written in ink underneath).
Page 1 states "The serial number plate can be found on the front part of the main frame, right hand side."
If you would like any copies out of this catalog, give me a shout.
Alan
Brian in Ohio
11-23-2003 10:41:15
The 10-18 used the same type of serial number plate that the steam engines did. The 12-20 and 18-32s used a nameplate similar to what is seen on the toolbox of an "L" or "C", and is riveted to the inner left hand fender.
Mike Schotte
11-23-2003 06:20:11
I haven't ever seen an 18-32 up close and personal... but the serial number plate on a 10-18 crossmotor is on the frame inside the right front wheel:
third party image
I have no idea whether or not the frames were stamped with the serial number as well (like the later tractors were.)
-Schotte
Brian in Ohio
11-23-2003 05:08:06
I'm not certain if it is the same as a 12-20, but the serial number on my 12-20 is behind the driver's left hand front wheel. The area of the frame that runs paralell to the engine block, right along the edge. You do have to look close, it is not very obvious.
