VAC gas line
Ray Hoffman
12-10-2003 18:10:42
This line is made of seamless steel, identical to brake lines, 16-inches long with a slight "S" curve, and compression fittings on both ends. It should go behind the air-cleaner mounting bracket. You do not have to completely remove the a-c bracket, just loosen it enough to get the fuel line to slip in the 'swell' formed at the factory for this line to pass behind the bracket. They should never be out in front of the air cleaner. Suggestion: just lightly start both ends by hand before snugging things up. After they are tightened, then carefully bend the line so there is not contact with the block.
