1170 pto problems
Shaggy
12-16-2003 08:39:42
Hey I got the right numbers this time! The problem is the PTO won't shut off. Is there a cable adjustment or some kind of brake adj. Thanks. (Sorry about the last one.1477? to many Bud light's)
Doug
12-16-2003 18:05:50
 Re: 1170 pto problems in reply to Shaggy, 12-16-2003 08:39:42
ok under the right side of the platform is a cable that goes to the valve body. ok that is where the adjustment is. have someone move the lever to see if this cable is moving. if it doesnt move the cable is broke if it does move it might be out of adjustment. adjust as necessary. hope this helps. valve body is next to the hydraulic filters. hope this helps. have a 970 that had this problem
Jim Handke
12-16-2003 09:50:07
There is a brake that stops the drum from turning when the pto is shut off. You have to pull the housing off the rear of the tractor to repair. If the pto is on constantly, the cable might be broken. That's what happened on my 2470. The cable must pull the spool out(on the flow divider)to shut the pto off.
