1955 case 410 timing marks
lonnie
12-20-2003 15:31:28
have a 1955 case with a timing marks of 20-35 deg also have a mark on the flyweel i guess this is tdc i would like to know what the timing is at what idle speed also which one is number one plug is it the one that is close to the radiatior thanks
Jerry
12-21-2003 07:21:10
 Re: 1955 case 410 timing marks in reply to lonnie, 12-20-2003 15:31:28
Lonnie,
This is from my manual.
Start and operate the engine at 1360 RPM and hold tming light on crankshaft pulley timing pionter.If the ignition is timed correctly the 26 degree mark on the crankshaft will be aligned with the pionter as seen with the timing light.
I hopre this will help you need more infor drop a line and ai will see if I can help you out
Happy Holidays. Jerry
lonnie
12-21-2003 13:03:16
 Re: Re: 1955 case 410 timing marks in reply to Jerry, 12-21-2003 07:21:10
thanks jerry
