1966 case 430
walt miles
12-22-2003 18:07:12
I have a Case 430 that I recently changed points on .The man at the parts store told me to gap them at 25,000 but the tractor is still missing . Do I need to close the gap more or open it more to smooth it out?It is a four cylinder gas tractor.
Dennis/Ohio
12-26-2003 03:43:33
 Re: 1966 case 430 in reply to walt miles , 12-22-2003 18:07:12
Points are .020" plugs are .025" You should find a local mechanic to give you a hand. Timing is set with a test light because timing starts to advance as soon as this engine starts. You can only use a timing light if checking total timimg advance at full throttle. Hope that helps, Dennis.....
Klyde
12-22-2003 19:37:23
Plugs .025" points are prob around .016"
gerald inTX
12-23-2003 18:31:47
 Re: Re: 1966 case 430 in reply to Klyde, 12-22-2003 19:37:23
I want to change my 4-spd tranny to a triplerange.
Ihave a triple range parts tractor. How is the best way to do this?
Dennis/Ohio
12-26-2003 03:53:07
 Re: Re: Re: 1966 case 430 in reply to gerald inTX, 12-23-2003 18:31:47
I suggest a parts manual to compare part numbers of what pieces are different. New oil seal between 4 speed and torque tube is a must. You'll be upset if you have to do it later (and you will). Best wishes, Dennis..... .
