200B Triple Range Questions
Tom Moore
12-30-2003 05:35:56
I have found a Case 200B Triple Range for sale for $3000. It seems to run fine but could use some cleaning up. I haven't been able to find much information on the 200B. I was told it is a 1957 model. I calculated the Hp to be about 33 based on a displacement of 126.5 cubic inches, 7.5 compression ratio and a "full Load Engine Speed" of 1900 RPMs, is this correct? Is this a good deal? Are there particular problems with this model or transmission? I plan to use this for mowing and around the farm for general-purpose work. Any information would help? Thanks, Tom Moore
case poor in pa
12-31-2003 06:28:04
 Re: 200B Triple Range Questions in reply to Tom Moore, 12-30-2003 05:35:56
if that tractor is a dandy all restored decently and evrything workin like new. you can buy a 730 case here in my area for 3000.00. but then again they didnt make to many 200s. dont qoute me but seems like i heard some parts are gettin hard to find . i gave 2500 last fall at auction for a purty nice 530 case.in north central pa... but if you consider they are getten for lawn tractors .i dont understand these things... im gone...
Tom Moore
12-31-2003 06:39:26
 Re: Re: 200B Triple Range Questions in reply to case poor in pa, 12-31-2003 06:28:04
Thanks for the feedback, I'm starting to think it is a little overpriced. The fact I can't find much information on it makes me think that parts may be hard to come by..... ....Tom
Joe (Wa)
12-30-2003 15:38:02
Neb Lab test #688....211b hp 30 pto & 26 drawbar.
Tom Moore
12-31-2003 06:40:39
 Re: Re: 200B Triple Range Questions in reply to Joe (Wa), 12-30-2003 15:38:02
That seems to be in line with my caculations. Thanks, Tom
C. Amick
12-30-2003 10:02:59
I have a Case 300. I paid $1,600 for it. It had a bad rod bearing, a broken grill, and no lights when I got it. On the 300 (and I assume the 200 is similar) the triple range transmission serves as the reservour for the hydraulic pump. Keep a check on the oil level. It doesn't have a live PTO as such. It has a hand clutch lever that allows you to stop the tractor wheels and leave the PTO running. Sorry, I don't know the rated horsepower of the 200.
Tom Moore
12-30-2003 11:18:32
 Re: Re: 200B Triple Range Questions in reply to C. Amick, 12-30-2003 10:02:59
Thanks for the info, this helps allot!
