1175 Case More Power
Ryan
01-01-2004 16:41:42
Wondering if you can put injuectors out of a 2870 in this 451 and if so do you have to change the injector lines. Would you be able to get enough fuel out of the stock pump. Any suggestions on what kind of power you could get with this combination would be appreciated.
big orange
01-01-2004 17:53:29
 Re: 1175 Case More Power in reply to Ryan, 01-01-2004 16:41:42
1270 injectors and pump specs will make at least 185 hp.
Shane
01-01-2004 19:19:45
 Re: Re: 1175 Case More Power in reply to big orange, 01-01-2004 17:53:29
How do you figure that 1270 settings will make 185 horse? The 12's were rated at 127 horse or 135 horse, so how would setting the pump to factory 1270 specs generate 185 hp? Wouldn't it make the roughly 130 horse the 1270 does since it is the same engine bore and stroke and pump and injectors.
Thad
01-02-2004 03:48:17
 Re: Re: Re: 1175 Case More Power in reply to Shane, 01-01-2004 19:19:45
You can turn the fuel screw up on any inline bosch pump. I have a 1175 with a 504 from a 1570 putting out around 350hp thats a guess because my dyno only goes to 300 and i can peg it out. You just need to know what to do to the pump. Thad
Shane
01-02-2004 09:12:31
 Re: Re: Re: Re: 1175 Case More Power in reply to Thad, 01-02-2004 03:48:17
I understand you can get more horse by turning up the pump but if you set the 1175 to the 1270 specs how do you get 185? I think both tractors use the A451BDT, 451 cubes and turboed.
Thad
01-02-2004 16:02:32
 Re: Re: Re: Re: Re: 1175 Case More Power in reply to Shane, 01-02-2004 09:12:31
You wont get 185 at stock 1270 specs. Thad
turbo
01-01-2004 16:55:34
The 674 CID Scania engine in a 2870 used a larger bore Lucas nozzle if I remember correctly. Will not fit in the Roosa-Master pencil nozzle hole.
turbo
01-01-2004 17:11:34
 Re: Re: 1175 Case More Power in reply to turbo, 01-01-2004 16:55:34
The 4 1/8 and 4 3/8 bore engines use the same nozzle.
The 4 5/8 bore engines use a nozzle with a spray pattern a few degrees less due to the larger bore. The hole sizes and number of holes are the same between the Roosa-Master pencil nozzles used in Case engines. Nozzles will not change power.
