CASE L 1937
Dave Alexander
06-17-1999 17:17:33
I have a Case L that I want to pull, problem is it doesnt have enough traction, it isnt heavy enough on rear wheels. It has 1400-28 rear tires but they are mounted on converted steel rims. (no cast hubs and no where to attach wheel weights. Does any one know if cast hubs off of an LA (casting #A5231A) will adapt to L axles.
casetractordude
06-26-1999 16:27:10
 Re: CASE L 1937 in reply to Dave Alexander Canada, 06-17-1999 17:17:33
I would not change your wheels. Just make tubes that will bolt on to your pressed steel wheels that will fit your weights. Make the tubes stick out far enough you can put several weights on them. You can just sl;ide them off and on.
Remember you can run a higher gear because you have so much HP to weight.
