2390 brake linings (or lack of !!!!!!)
Tremayne Hadenf
01-16-2004 15:24:40
I just started tearing apart my 2390 rear end to fix the brake linings that came apart in it.
1) why does the linings come apart on these? I have replaced worn clutch and brake linings in other equipment, but not because they came apart.
2) if it was a Case problem, did they rectify it?
3) What about getting linings refitted to the old plates instead of buying new? Who does it
4) anything else to look at or replace why the rear end is apart?
thank you
tremayne
david
01-18-2004 16:35:38
 Re: 2390 brake linings (or lack of !!!!!!) in reply to Tremayne Hadenfelt, 01-16-2004 15:24:40
i've had the same trouble usually it is the pto but it is the same thing dealer says it had the wrong oil at some time?i've asked the same ? never got a great answer.you don't have the pto out do you?
Tremayne Hadenfelt
01-19-2004 15:07:42
 Re: Re: 2390 brake linings (or lack of !!!!!!) in reply to david, 01-18-2004 16:35:38
The wrong oil theory I do not beleive. The wrong glue, pad, or process for adhereing the lining I would beleive. My pto works as far as I know (never used it). The pto housing is out & I have heard that when you have problems with them, it is good to change all of the linings- so that is what I am going to do. Bad thing though is I found 1 ring gear bolt missing, found the washer under the hyd screen. Can't find the bolt. Might have vacuumed it up during the summer when I first tore it apart.
hadenfelt@comcast.net
Jeff From WI.
01-17-2004 08:11:42
Hey Hadenfelt, My Computer Crashed & I lost your e-mail. I Still don't have my e-mail working correctly yet but i'm hopeing to soon. Hope everything is well with you and yours. Jeff
