830case hydraulics
F.Stewart
06-20-1999 07:15:56
The hydraulics filter on my tractor collapsed.I changed it . and the fluid also had some water in it.I also changedthat. but now the lift will hardly pick up.and will only lift at high rpms with no load.But somtimes will lift a small load. Are there any more filters or screens that could be changed or cleaned.Any suggestions would be apreciated.thanks classic359@aol
john
06-25-1999 17:19:39
 Re: 830case hydraulics in reply to F.Stewart, 06-20-1999 07:15:56
Check suction tube for any build up, make sure suction line is clear from pump to end of line. plate in back of tractor to pull off. Drain fluid first.
F Stewart
06-26-1999 15:02:47
 Re: Re: 830case hydraulics in reply to john, 06-25-1999 17:19:39
Thanks so much for your response.DOyou know if it has 1 or 2 hydraulic pumps and the location.THANKS.classic359@aol
