1070 draft control valve
dudley
01-18-2004 15:07:24
3 point on this tractor will stop working or work very slowly with almost no pressure. Sometime while working in the field or sometimes when tractor has set for a while. Only way to get working correctly is to dissasemble draft control valve and reassemble. have found no trash or foreign material in valve and no reason for it not working but will work correctly when reassembled. Changed hydraulic oil and filter twice to ensure good clean oil and pump is putting out recommended flow and pressure. Tried a used valve from a junkyard and have same results. Has anyone else had this trouble or know of any ways to correct it. Any help is greatly appreciated, I'm stuck as to what to do with it.
Hey Dudley:
01-18-2004 17:22:25
 Re: 1070 draft control valve in reply to dudley, 01-18-2004 15:07:24
Years ago I had the same problem with my 1175. Took the valve off & did the same thing you did. However, a used valve from a bone yard solved the problem.
