CASE SC MAIN BEARINGS
MIKE S
01-23-2004 09:40:27
I'VE FOUND A BEARING SUPPLIER HERE IN NEW ENGLAND THATS WILLING TO TRY TO CROSS REFRENCE MAIN BEARINGS TO A CURRENT PART FOR THE CASE SC TRACTOR. WHAT I NEED IS THE ORG. FACTORY PART NUMBER IF POSSIBLE, AND THE SIZE OF THE CRANK BEARING JOURNAL, AND THE SIZE OF THE MAIN IN THE BLOCK, THE WIDTH OF THE BEARING, AND WIDTH OF THE THRUST BEARING, AND WHERE THE ALIGNMENT TAB IS LOCATED. THE SAME FOR THE ROD BEARING IF POSSIBLE. IF I FIND A MATCH I WILL POST THE RESULTS!!!!! I WOULD USE MINE AS A REF. BUT MINE IS STILL ALL TOGETHER AND NOT KNOCKING. THANKS IN ADVANCE.
John Saeli
01-24-2004 10:49:24
 Re: CASE SC MAIN BEARINGS in reply to MIKE S, 01-23-2004 09:40:27
Hey Mike: I don't have the dimensions handy, but the part numbers are: O5703AB Liner, and O5704AB Liner. The latter is the center main. That first digit of the part number is the letter "O", not a number. Makes a difference to a computer. Keep us posted.
MIKE S
01-25-2004 06:38:29
 Re: Re: CASE SC MAIN BEARINGS in reply to John Saeli, 01-24-2004 10:49:24
THANKS FOR THE INFO I'LL SEE WHAT HAPENS!!!!!
