530 CASE TRACTOR DIESEL
MIKE
01-30-2004 06:27:32
THERE IS OIL LEAKING ONTO THE CLUTCH FROM THE ENGINE IF I HAVE TO CHANGE THE SEAL IN THE ENGINE, CAN I CHANGE IT FROM THE OIL PAN (SPLIT SEAL) OR DO I HAVE TO PULL THE ENGINE TO CHANGE IT. ALSO NEED A PART # FOR THE SEAL ANY SUGGESTIONS WHERE TO FIND IT. THANKS FOR YOUR TIME
Klyde
01-30-2004 09:49:33
 Re: 530 CASE TRACTOR DIESEL in reply to MIKE, 01-30-2004 06:27:32
Nope, gotta split it. Flywheel has o come off to get the seal retainer out. Prob get the seal from any NAPA or CASE.
Mark
01-30-2004 07:16:49
Case Dealer will have the part you need. If its like a Chevy small block, you can do it from the oil pan.
