1951 DC-3 Oil Level? Where? How Much?
Chris Hibbert
02-24-2004 07:20:55
I know I have seen the answers before but I cant seem to find them searching the archives.
On my DC-3 Where do I check level on the oil? How many different oil areas are there? (I thought there was 1-Engine Oil, 2-Transmission Oil, and 3-Hydraulic oil - am I right?)
Does the engine and transmission use the same oil viscosity/grade? What is recommended for it? I use the DC-3 to spread manure via a ground driven manure spreader and to mow pasture (around an acre) with a 5 foot PTO driven deck.
I could just use all the info on any lubricants necessary in this machine as well as grade/type and capacity.
Thanks so much,
Chris Hibbert
todd hamilton
02-24-2004 15:17:38
 Re: 1951 DC-3 Oil Level? Where? How Much? in reply to Chris Hibbert, 02-24-2004 07:20:55
Recommend purchase of service and operator manuals - you can get a set of reprints for about $50.00. I find them most helpful with maintaining my SC.
dctom
02-24-2004 13:26:28
NO THE 1/2 " PIPE PLUG AT BOTTOM OF CLUTCH HOUSEING, SAME KIND OF PLUG THAT YOU DRAIN OIL PAN, WHEN YOU DRAIN OIL FROM ENGINE YOU SHOULD BE ABLE TO SEE THE PLUG BACK OF ENGINE FLANGE
dctom
02-24-2004 07:58:01
DC-3 ENGINE OIL AT TOP PLUG, 6 QUARTS WITH FILTER TRANSMISSION AND REAR END, 10.5 GAL 80-90 HYDRALIC NNONDETERGENT SAE 30
DONT FORGET TO DRAIN CLUTCH HOUSEING WHEN CHANGEING OIL, NO NEED TO PUT ANY IN AS IT IS PUMPED THRU CLUTCH
Chris
02-24-2004 09:52:18
 Re: Re: 1951 DC-3 Oil Level? Where? How Much? in reply to dctom, 02-24-2004 07:58:01
By the clutch housing, do you mean the rectangular entry plate beside the clutch?
