2590 brakes ?
Tim
02-28-2004 18:36:34
My 2590 has no brakes on either side. Went to buy new brakes at dealer, he said he thinks it might be a valve problem. I have nothing when I step on pedals. When I bleed them I get a little fluid but not much. Any advice would be greatly appreciated.
Roger
02-28-2004 19:19:00
 Re: 2590 brakes ? in reply to Tim, 02-28-2004 18:36:34
I have a 1370 that I am going to need to bleed the brakes before field work, I was told to have the engine running when bleeding then open each bleed screw above the rear axles & let it run until no more bubbles, nothing was said about pumping the pedals like on a car. It did make a difference. I would have someone else there to help, at least sitting in the cab in case something happened since you would be down by the tires when it's running.
