Case 1030 pto adjustment
Bud
07-06-1999 11:17:29
pto on case 1030 runs all the time. Is there some adjustment that can be made to stop and start the pto? Also the handle is very slack. thanks
SPF in WI
07-06-1999 16:25:23
 Re: case 1030 pto adjustment in reply to Bud, 07-06-1999 11:17:29
My best advice, would in these situations would be to get a CASE service manual or I&T service manual.you will find these manuals can be your best freind
Jerrie Lott
07-07-1999 20:09:39
 Re: Re: case 1030 pto adjustment in reply to SPF in WI, 07-06-1999 16:25:23
There is a brake inside there that can be adjusted, but if it is like mine it wore so bad it will not make contact. Mine only runs when it is coldwhen it gets above about 65 the oil is usually thin enough that it don't run or quits as soon as the tractor warms up. But you do need a manual because to describe how to adjust it would take a couple of pages.
