1816 steer problem
Fern(Mi)
02-29-2004 16:31:21
1816 skid steer steers slugish and slow to right with left lever. Yet with same lever it steers quikly and speedily right. Before I start taking this machine apart, can this problem be in the steering linkage? Or, is this just an inherent quirk I have to live with"
Mel
03-02-2004 18:32:20
 Re: 1816 steer problem in reply to Fern(Mi), 02-29-2004 16:31:21
Silly as it may sound check your belt tension from the engine to the dive pumps, 1816,s had an issue with that and most sluggish problems can be cured by careful adjustment, Mel
Max
02-29-2004 19:56:27
Sounds like you may have a worn Hiem joint on the steerng linkages.
