Case 444 engine swap
Shine
07-07-1999 09:42:03
Have a Case 444 garden tractor w/ 14 hp Kohler engine, Model K321A, spec 60117d (no serial no), year unknown. Can this engine be be replaced w/ a new Kohler magnum series 12 - 16 hp engine?
steve
06-18-2002 17:07:33
 Re: Case 444 engine swap in reply to Shine, 07-07-1999 09:42:03
I have aquired a case 444, the preveuse owner used engien oil in the hydralic system wich made the pump stiff and the motor would not trun over. is there an easy way to flush the system with out takeing it all apart
Dweber
07-09-1999 07:30:59
You had better check the back of the block where
the pump bolts, I'm not totally sure how ever I believe the block was cast specifically for that
pump to mount.
