'49 VAC MOUNTED PLOW-NEED MOUNTING INFO
jimmy z
03-20-2004 22:06:13
LOOKING FOR SOMEONE FAMILIAR WITH HOW THE 2-BOTTOM [NO MODEL # YET] MOUNTS TO TRACTOR. I HAD IT HOOKED UP LAST SRING AND PLOWED FINE, THIS FALL , HOWEVER, "MYSTERIOUSLY" THE TWO BOTTOM BRACKETS DID NOT LINE UP CORRECTLY[WHERE LARGE PINS PASS THROUGH TRACTOR BOLT-ON BRACKETS]. IT DOSEN'T SEEM LIKE ANYTHING TWISTED OR SHIFTED OR GOT BENT. BUT THEY MOUNT "OFF-SET". I'M GOING FROM MEMORY AND THIS JUST DOSEN'T SEEM CORRECT, BUT IT STILL PLOWED OK. ALSO, SINCE "HANDS-ON" OR A SKETCH WOULD HELP, I WAS HOPING TO CONNECT WITH SOMEONE WHO HAS ONE OF THESE SET UPS IN THE ERIE, PENN AREA. MY NIEGHBOR DAIRY FARMER/CASE COLLECTER HAS A VAC WITH EAGLE HITCH- BUT MINE IS NOT AN EAGLE HITCH. DIDN'T CASE START THEM IN '48? MAYBE THIS WAS AN OPTION BEFORE '50 ? THANKS- JIMMY Z. AND HIS NEAT VAC.
mj
03-21-2004 07:50:44
 Re: '49 VAC MOUNTED PLOW-NEED MOUNTING INFO in reply to jimmy z, 03-20-2004 22:06:13
If it's a 2-way plow you can see some photos on my site.
jimmy z.
03-26-2004 19:59:30
 Re: Re: '49 VAC MOUNTED PLOW-NEED MOUNTING INFO in reply to mj, 03-21-2004 07:50:44
mj- thanx for the response. i was off line for a week. my mounted two-bottom plow isn't a two way,but i see from your photo, there are similarities to the mounting.however, mine will not "match up" equally to the pins. like i said, i don't think anything got bent, but it dosen't go together like it did before..... i was hoping to view someone's set up to compare to mine. thankyou for your help. jimmy z.
jimmy z
03-30-2004 19:20:08
 Re: Re: Re: '49 VAC MOUNTED PLOW-NEED MOUNTING INF in reply to jimmy z., 03-26-2004 19:59:30
still looking for someone in the ERIE,PA area that has a mounted two bottom to look at- any leads, PLEASE respond. THANK YOU ! jimmy z
