2290 case head
KY Case
03-22-2004 08:35:35
I have a 2290 case one head has water comming out between head and block (no water in oil) could this be a cracked head or a bad head gaskit? Do these tractors have this kind of problem often? The tractor runs fine and has no blow by. Thanks for the help KY Case
Elmer
03-22-2004 18:55:29
 Re: 2290 case head in reply to KY Case, 03-22-2004 08:35:35
Put another head gasket in it. I have seen that before. Make sure you do all three. There not bad to do, but while your at it change all the exhaust manifold studs too. There likely rotten!
