What 930 rearend/trans parts will fit a 1030 ?
Tremayne Hadenf
03-29-2004 11:06:25
Ended up with a 4 speed hi/lo tranny and rear end from a case 930. I have a 1030 and was going to keep what parts from the 930 assembly that would interchage. I have the axle housings, rearend, tranny, CK fenders. It is still assembled. What will fit/ what should I keep for spares? Other than spares for my 1030 I have no use for it (scrap).
Would the rearend assembly bolt to a 830 dsl? I have a 830 dsl with a bad COM (no direct drive).
thanks
tremayne [hadenfelt(at)comcast(dot)net]
Jerry
03-30-2004 04:39:31
 Re: What 930 rearend/trans parts will fit a 1030 in reply to Tremayne Hadenfelt, 03-29-2004 11:06:25
Where are you located? Do you want to sell the 830? I do not know if the flywheel will work on the change over.
Jim Handke
03-29-2004 13:58:55
The 930 rear should bolt up to the 830. As far as I know, the 930 and 1030 rear end/tranny is the same.
