42' Case VC
Ron
07-13-1999 16:51:03
I recently purchased this VC. I need information on the hydraulic lift and the 3 point hitch. The lift itself works. I had read somewhere that only the VAC had the lift, but the guy I bought the tractor from swears it's a VC. Serial number 4631576.
al
07-15-1999 06:10:42
 Re: 42' Case VC in reply to Ron, 07-13-1999 16:51:03
I have a 41 vc Case with the Power lift.It is mounted on the rear with & extra long power take off shaft extending through it.Runs off the power take of shaft.I have a Jensale Case Manual.If you are going to be working with Case tractors I recommend one.Think they advertise at this site.
TMAC
07-13-1999 20:09:07
I'm not sure if its a VC or VAC by your serial number but I can say if the engine is a flathead, it is a Contenital engine and the tractor is a VC. The lift saw the light of day on the VA models.
Ron
07-14-1999 03:40:01
 Re: Re: 42' Case VC in reply to TMAC, 07-13-1999 20:09:07
Have you seen a working lift/hitch assembly? I would like to find one to add to the tractor. I have the manuals for the tractor, but they do not give any information or diagrams on the hitch or lift. Does anyone have a picture of a working one?
