188 diesel engine problem
Chris
04-10-2004 04:38:05
I have an old 580 ck backhoe powered by a 188 diesel that I use on the farm. About three weeks ago I was using it to clean the driveway when it stalled. I restarted it and it stalled again. this was unusual so before starting it again I looked further to determine the cause. I determined there was no coolant left. I checked the crankcase and was relieved to find nothing unusual. I proceded to fill the coolant when it came pouring out the block heater. I decided that it was time to replace the rotten exhaust manifold. I ordered a new aftermarket one. The next week when I started it up to move it to a convienant work location, I noticed a substantial amount of the new coolant was coming out of the rad. I thought I had over filled it. after I removed the exhaust manifold I found a piece of a head bolt on the top of the engine. upon further exam I noticed a slight amount of coolant at the joint of the head and block between exhaust port 2 and 3. I suspect (hope) it is just the head gasket. Who has thoughts? what is involved in removing the head on the 188 diesel and who has a manual for sale??
Thanks in advance Chris
Roger (Mi)
04-12-2004 04:43:19
 Re: 188 diesel engine problem in reply to Chris, 04-10-2004 04:38:05
To remove the cylinder head on most 188 diesels, the water pump MUST be removed. There is a bolt INSIDE of the water pump housing that screws into the cylinder head. Reassembly: progressively torque the head bolts to 100 lbs. and then set the intake and exhaust valve clearances at (.014).
