1816B case uniloader
floyd wells
04-13-2004 21:34:36
I have an 1816B uniloader that I have had for about two years and have had no problems with, but after using it on a driveway tile removel project it has a problem with the forward and revers drives I checked the psi on each pump and I am getting 2000 psi at each one. One more thing that I fond that was a little funny was that when you move the left lever forward a little bit it will start to move but when you move it all the way forward it squieals and will not move till you let off a little. The pump on the left side's belt is little bit tighter but the right side will do the same thing but not as bad.
