Can't locate ser. no.
Pat
07-18-1999 20:00:41
Someone said it was where eng. bolts to rear end, in center of tractor....?????
Is it on the bell housing, or what would be the bell housing on a car?
Can someone describe its location more specifically? On top, right or left side? How far back from end of eng. block? No plates near gauges or firewall either.
martin
07-20-1999 05:49:42
 Re: Can't locate ser. no. in reply to Pat, 07-18-1999 20:00:41
There is no plate, it is stamped into the casting
on the end of the block on a lip where the block attaches to the rearend. It is on the left hand side, on a DC, directly right of the air breather oil cup. If you don't know what that is, it is what the carb is hooked to. I hope this helps.
