1979 Case 580 C Motor Oil Capacity Oil Filter #
Ed
04-26-2004 06:20:43
Hi,
I pick up a 1979 Case 580C backhoe. I was wondering if anyone knew off-hand the motor oil capacity (15w-40 or 30W ???) and also the oil filter #?
Thank You ahead of time.
Roger (Mi)
04-30-2004 05:17:51
 Re: 1979 Case 580 C Motor Oil Capacity Oil Filter in reply to Ed, 04-26-2004 06:20:43
The 580C followed the 580B which followed the 580. They're all CK's (Construction King).
I use a diesel grade 10W-30 in the winter and 20W-50 in the summer. The oil filter is the same as the one used on Ford V8's.
Jim B
04-26-2004 12:36:50
If you mean a 580CK, the Operators Manual says > it holds 4 quarts plus one for the filter. Diesel engine oil should be DS service classification. Gasoline engine oil should be MS service classification. Viscosity rating is: SAE 30, above 80F; 20W, 80F to 32F; 10W, 32F to -20F; 5W or 5W-20 below -20F. Engine Oil Filter is Case part # A146696, Fleetguard # FL35530. Although I don't think the CK was built in 1979. Of course, I live with "Yesterday's Tractors" and maybe there is a 580C from 79! Which I would consider to new, say costly, to be a YT.
