1210 david brown water pump
Jeff
04-27-2004 10:11:02
I am rebuilding the water pump in a 1210 David Brown tractor that I just purchased. The pump body does not have the threaded hole needed for the locator screw supplied in the kit. I can drill and tap to install the screw but is it neccessary? Can anyone tell me the purpose of the screw as I see it is vented?
Elmer
04-27-2004 16:24:21
 Re: 1210 david brown water pump in reply to Jeff, 04-27-2004 10:11:02
The early pumps had grease nipples, so the screw had a flat side to allow grease into the bearing. Just go ahead and assemble it. Make sure the bearing does have a good fit though.
