1070 rear end noise
dcman
04-27-2004 22:11:40
I just got a 1070 in that has like a clanking noise in the rear end in 4th range. It does have the power shift trans and is a 78 model. Only makes the noise in 4th range when it has any kind of a load on it, but dont' hear it when it is on flat ground. Rest of gears are quiet. Does do it in all speeds of 4th range. Any ideas of what could be wrong??? This will be the 3 time this tractor has had rear end problems.
Roger (Mi)
04-29-2004 04:54:53
 Re: 1070 rear end noise in reply to dcman, 04-27-2004 22:11:40
David is right. Look for a missing gear tooth on the 4th speed gear set. That gear set is really small and will not take much abuse.
david
04-28-2004 20:58:03
i just replaced 4th gear in trans. 2 teath chipped? only did it in 4th sounds like the same problem.
