Case 530 Crankshaft
Charles C
07-19-1999 18:21:26
New at this
Looking for a crankshaft source for a case 530
part numbers G11889 old or A39150
Dealer has new for too much.
thanks
Frank
07-20-1999 17:34:21
 Re: Case 530 Crankshaft in reply to Charles C, 07-19-1999 18:21:26
I too needed a crank for the G159 Case 530. I found a new one at a salavge yard with part #A37210 for $375 (new price over $800.00) This crank shows up in the "Where Used" micro-fich at the case dealer for the Case 530. The only difference I have found so far is the flywheel end (has a spleen drive instead of a pilot bearing, I drilled my out on my lathe to use a pilot bushing.) The rest seems to be the same as #G11183 (new cost over $1100.00, which I belive shows no longer availabe from Case)
I did find a used reground crank from Pleasant Hill Fram Salvage, Pleasureville, KY (502-845-4467) for about $500.00.
Most Salvage Yards I talked to, magna flux and reground before selling.
I hope to fire up the engine in a week or two. Case Dealer still trying to find one more new piston. (looks like I will have well over $3000.00 invested in rebulid, not including my labor before complete.
