2290 Case Tractor
Reid
04-30-2004 18:51:16
My 2290 Case Tractor is about a 1977, '78 or '79. Is there a way to bleed air from the hydrolic system? And how do you adjust the clutch, because when in gear it won't move?
Keith
05-12-2004 09:38:12
 Re: 2290 Case Tractor in reply to Reid, 04-30-2004 18:51:16
Does anyone know if a front axle from a 2394 will mount on a case 2290? we break spindals off all the time and are costly to repair
MHF
04-30-2004 19:28:20
If your tractor is a powershift your torque limiter sounds like it is out. On your hydraulics try changing filter. If it is a powershift let clutch out then try to put in gear if it does not grind then your torque limiter is out.
Reid
04-30-2004 19:38:11
 Re: Re: 2290 Case Tractor in reply to MHF, 04-30-2004 19:28:20
Thank you, Do you have to split the tractor to fix it?
MHF
04-30-2004 19:41:47
 Re: Re: Re: 2290 Case Tractor in reply to Reid, 04-30-2004 19:38:11
If it is the torque limiter yes it is bolted to the flywheel. Did you try putting in gear with the clutch out.
Reid
04-30-2004 20:08:06
 Re: Re: Re: Re: 2290 Case Tractor in reply to MHF , 04-30-2004 19:41:47
No, not yet, I will try it tomorrow, and then I will post what I find out. Thank you for your advice, and I will get back to the message board as soon as I do. Thank you.
