2390 Powershift adjustment
Shane
05-01-2004 10:04:33
Have a 2390 that shifts fine from 1st to 2nd but from 2nd to 3rd there is a slight hesitation. What ports and which way to turn the screws to firm up the shift? Thanks for any helpful info!
Jim Handke
05-02-2004 10:41:19
 Re: 2390 Powershift adjustment in reply to Shane, 05-01-2004 10:04:33
When using the blinky box, you set C-2 by upshifting from low to intermediate. You set C-3 by downshifting from high to intermediate. Check the inching spool. When my 1070 did that, the cab mounts had let the cab settle enough that that spool wasn't setting in the valve body correctly. Also on my 2470, dirt settles in front of the powershift spool. When it pushes enough crud ahead of it, that spool doesn't move out quite far enough, causing the same problem. You shouldn't have that problem, unless something has fallen into it's path.
Don
05-01-2004 22:08:34
I don't think turning the screws will help the shift from 2-3 or 3-2. They are for 1-2 and 2-1.
