377 engine interchange
gb
07-20-1999 07:08:20
Can anyony tell me if the 377 basic block is the same as the 504 or other big Case blocks. Will the 504 bolt up to the 900 bell housing. Thanx in advance. gb
Bryan
07-21-1999 06:09:32
 Re: 377 engine interchange in reply to gb, 07-20-1999 07:08:20
The 377 engine in the 900 uses a wet clutch which is a diferent bell housing than any other engine.
jJerrie Lott
07-20-1999 08:12:04
As far as I know it is. Iknow that you can put the later enginesin the "30" series tractors. You have to drill a hole for the steering shaft to go through and the exhaust is on the opposite side. Do you have enough rear end to take all this power. You are going from less than 70 hp to 125 or more, I think a 1370 has about 160hp. Good luck Jerrie
