You can get all kinds of Case parts at my brothers site LinkPART NO. CASE TRACTORS MODEL VC,VAC PART NO. 727 Piston ring set for V / VC 3" bore ..... ..... $46.00 | F600I228 Exhaust valve for V/VC ..... ..... ..... ..... ..... $12.50 2C7751 Piston ring set for VA /VAC 3 1/4" bore .$56.00 | 03782AB Fan belt (for use without generator) VC,VAC.$11.50 VT2299 Radiator cap gasket for"V/VC"series only .$2.00 | VT35 Radiator cap W/O clip-spring"V/VC"..... ..... ....$20.00 F7519S Full overhaul engine gaskets for VA-VAC $92.00 | VT3641 Wooden hood prop ..... ..... ..... ..... ..... ..... ..... . $6.00 B51772 Carb float VC or VAC Marvel Sch. carb.... $8.00 | B51776 Large Marv.Sch.carb float430/530/630..... ..... .. $23.00 VT3589 Oil filter for VAC,200,300,310,400,600B.. $7.75 | VS6907R Valve cover gasket 124-159 engine..... ..... .....$11.50 PK257 Sleeve & Piston kit W/ rings,wrist pins,& "O" rings set of 4. $450.00 F7183PT Full overhaul engine gaskets for V / VC less timing cover.... $80.00 VAC CASE Decal set ("VA" decal set available for the same price)..... $18.25 BK54 Basic carburetor kit for VA/VAC Marvel Schebler #TSX114... $16.00 BK55 Basic carburetor kit for V / VC Marvel Schebler #TSX43 ..... . $16.00 Many new, new old stock, and used parts such as valves and gaskets are available. Call or write for availability. This is only stuff for VAC Case. Check the site for other models. Wayne
