Case VAC has oil getting into coolant
Mac
05-10-2004 19:19:20
My VAC has oil getting in the coolant and coolant in the oil pan. Removed head and gasket appears ok.Has anyone heard of this problem on a VAC and if so can there be any way to fix it short of replacing the block. Thanks, Mac
Augie
05-11-2004 09:27:50
 Re: Case VAC has oil getting into coolant in reply to Mac, 05-10-2004 19:19:20
Head gasket is the most likely culprit. Could also be a cracked sleeve or bad sleeve seal. Cracked block is way down the list of suspects.
