830 Case Comfort-King flooding
Kory Kroeger
07-21-1999 17:37:36
My 830 Case when parked in the shed with the gas left on will flood itself. I always have to turn off the gas.
Can this be fixed easily?
Thank you, Kory
Jerrie Lott
07-21-1999 19:37:11
 Re: 830 Case Comfort-King flooding in reply to Kory Kroeger, 07-21-1999 17:37:36
Sounds to me like the float is set too high. There is a certain distance it should be from the carb body when the needle valve is completely closed,or maybe the needle valve is wore enough that leaks into the bowl when the tractor isn't running, but I don't have the specs, maybe someone else does or your dealer has a service manual, that tells. Jerrie
