1210 power steering problems
Jeff
05-12-2004 18:17:46
I recently purchased a 1210 David Brown with the power steering reservoir separate from the pump. The system was full of engine oil, I flushed this out and refilled with light hydraulic oil. I also replaced the lines to the oil/air seperator with clear plastic. When running, there seems to be a lot of air and oil traveling up to the seperator and out the drain. Would bad seals in the pump be causing this or is it just a bad seperator? Any help is greatly appreciated!
Elmer
05-13-2004 02:42:58
 Re: 1210 power steering problems in reply to Jeff, 05-12-2004 18:17:46
It is sucking air past the shaft seal on the pump.
Jeff
05-13-2004 04:08:14
 Re: Re: 1210 power steering problems in reply to Elmer, 05-13-2004 02:42:58
Are parts available for this pump from another source other than Case/IH? My parts disk doesn't show a breakdown for this pump(K918993).
Elmer
05-13-2004 16:01:40
 Re: Re: Re: 1210 power steering problems in reply to Jeff, 05-13-2004 04:08:14
I can get an aftermarket pump, but Case has discontinued parts for them.
Jeff
05-15-2004 17:29:29
 Re: Re: Re: Re: 1210 power steering problems in reply to Elmer, 05-13-2004 16:01:40
The bearings are loose so the seal kit will not fix the problem. How much for a new pump and how do I contact you?
