dc serial #
sawwas
05-16-2004 08:49:09
where do i find the serial # on my dc case? thanks
SmartAxe
05-17-2004 06:53:04
 Re: dc serial # in reply to sawwas, 05-16-2004 08:49:09
Cast into the bellhousing where the engine bolts up to the trans, on the left hand side (as you sit on the tractor), is where you'll find the serial number. I'm assuming the dash tag is missing, since you're asking where the number is on the engine. You may have to scrape some paint away to get down to the numbers, but that's where they are. Good luck.
-Mark
sawwas
05-19-2004 10:03:46
 Re: Re: dc serial # in reply to SmartAxe, 05-17-2004 06:53:04
Looked better at left side of engine and seen "5026120" , but I can't see anything on the bellhousing. Can't find hide nor hair of a tag neither. I believe soon I'm gonna put some parts in classifiedad section. Thanks again..
Dave
05-16-2004 19:01:53
The # on the left side of the block is the serial #. Subtract 4 from the 1st 2#. It is a 1946. I just bought one too,Serial# 5000099.Case had a labor strike in 46 and only 1595 DC's were made that year. Dave
sawwas
05-16-2004 14:31:03
There are some casting numbers on the block ,the left side "502 12 D" , the right side "B4848A" and on the head "A5576A" ..... Trying to find out what year it was made, Thanks...
