1175 injectors
dw ECIL
05-17-2004 12:48:53
I was reading some of the older posts about getting more fuel to an 1175 and boring the injectors was mentioned. I am getting ready to put the new ones in, and was wondering if it is worth the time and expense to get them cut out. I am looking to pull in several non sanction (brush) pulls in the East central Illinois area. Any help?
Thanks-
doug
Thad
05-17-2004 17:49:15
 Re: 1175 injectors in reply to dw ECIL, 05-17-2004 12:48:53
No if you are running a stock 1175 pump. If you run a larger inj pump then i would consider bigger lines and injectors. Even if you turn your 1175 pump up as far as you can. Then i might run 1370 inj but most reman ones are the same. Hope this helps. Thad
