2090 power shift help
Dillon
05-17-2004 17:56:27
I have a 2090 that when letting out on the clutch it starts to take off and the last inch it just jumps. I have changed the control valve does the same thing any ideas would be appreciated.
gip
05-18-2004 10:57:36
 Re: 2090 power shift help in reply to Dillon, 05-17-2004 17:56:27
jumper tubes from housing to distubution hub could be leaking,are made of plastic,just replaced a ruptured one yesterday on c2 same symtom you are having
Jim Handke
05-19-2004 06:47:14
 Re: Re: 2090 power shift help in reply to gip, 05-18-2004 10:57:36
Never been inside a 90 series powershift. They replaced the three steel tubes with o-rings on both ends(70 series) with plastic? Do they still use those o-rings or have they IMPROVED that too? What were they thinking?
gip
05-19-2004 11:09:14
 Re: Re: Re: 2090 power shift help in reply to Jim Handke, 05-19-2004 06:47:14
Still use orings.I guess plastic is cheaper than steel????? ?
Jim Handke
05-18-2004 06:12:05
The C-2 piston seal is leaking. There isn't enough oil from the inching spool to offset the leak. When the spool is almost fully released, the full charge is released, overcoming the leak, activating the clutch.
