'31 Case L rear wheel removal
Nicholas A. Cov
05-20-2004 14:55:50
Hi there, I was wondering if any one could tell me if there is anything I need to do to remove the rear drive wheels, besides removing the axle nut. I see there is a key in it, but I am not sure of any other keepers. If anyone has any information I would appreciate it. Thanks in advance. Nicholas
Casenut
05-20-2004 19:49:56
 Re: '31 Case L rear wheel removal in reply to Nicholas A. Covey, 05-20-2004 14:55:50
Use a good logging chain and a bottle jack. put the stem of the jack against the axle shaft and wrap the chain around the wheel and across the base of the jack (it should come off fairly easily)
RoyG
05-20-2004 18:57:47
It is a tapered hub and shaft. May take a lot of heat and a good puller to get it off. Sometimes a good shat rap with a heavey shop hammer will do it
