1270 Brakes
Gpurrs
05-25-2004 16:57:54
I have 76 1270 with 3300hrs.When I push both pedals at the same time,the RH goes down 3/4inch farther than the LH.If Ipump them a few times they are the same until the next time.I have replaced RH line & piston seals,and all seals in the master valve.Ibought the tractor with 1000hrs its been this way since I got it.Any ideas? TIA.
Grumpy
05-26-2004 05:29:39
 Re: 1270 Brakes in reply to Gpurrs, 05-25-2004 16:57:54
Check the linkage between the pedals and the master valve. Take the bolt out of the pedal Pull linkage back adjust so linkage is one turn shorter than when bolt will slip in. Stan
